MAlha
7 years agoMy clock design is giving me an undefined output
Greetings, I'm trying to implement a simple clock generator design using Quartus II web version 11.1: However when I configured it onto my Cyclone II DE2 FPGA, it gave me a 0 output when I se...
JOHI
Contributor
7 years agoHello,
If you want a clock that can be used in a testbench, and that does work properly you can use someting link this (file.VHD):
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity DE10_STD_CLK_BENCH is
end entity;
architecture arch_DE10_STD_CLK_BENCH of DE10_STD_CLK_BENCH is
constant F_Clock : real :=50000000.0;
signal T_CLK : time :=1.0/F_Clock * 1sec;
signal CLOCK_50 : std_logic:='0';
begin
main_clock: process
begin
CLOCK_50<='1' after T_CLK / 2, '0' after T_CLK;
wait until CLOCK_50='0';
end process;
END architecture;Best Regards,
Johi.
