12 years agoMonitor 13.0 compatible with Quartus 13.1
Can you tell me if the Altera Monitor Program [Nios II] is compatible with Quartus II 64-bit Version 13.1.0 Build 162? The Monitor installer kept on asking me if I was sure I wanted to install Monito...
12 years agoI tried doing that, as far as I know, they are not compatible. you need to install Quartus 13.0 and then use monitor program 13.0.
I would suggest to go for Nios II 13.0 SBT for Eclipse if you are working on Nios II core as it is easier to handle and not much of a hassle. Hope this helps.
