15 years agoMemory Blocks
Hello Everyone, I created a RAM (Port 1 memory) using MegaWizard. Afterwards, I instantiated that module into a new verilog file. I have been asked to use toggle switches SW(7-0) to input ...
15 years agoPort out address bus and input them to a seven segment decoder. The output of seven segment decoder can display memory addresses as HEX digital on seven segment display.
You can apply the same configuration to memory inputs and outputs.
