Maximum operating frequency of MAX10
- 5 years ago
As per the datasheet, the max fOUT for -7 speed grade device is 450MHz. However, as per the note 29 in the datasheet, the fIN parameter is limited in the Quartus by maximum I/O frequency which is different for each I/O standard. Recommend to run the Timing Analysis and perform IBIS simulation to understand the maximum achievable frequency for your system.
In my opinion, 200MHz should be easily achievable.
