Shiva
7 years agoMAX 10 FPGA Remote System Upgrade (RSU)
Hi, I am trying remote system upgrade for MAX10 FPGA device, Here i am able to write and read the rpd data of CFM1 but when i trigger the reconfiguration it is not getting reconfigured. I am doing t...
JohnT_Altera
7 years agoHi,
May I know how much different are you observing? I suspect that there is some issue on your IP where it is not converting the data to Avalon-MM correctly. Will need to debug to understand what is actually happening.
Shiva
7 years agoHi,
The original data is 50 FF 47 FF but if i read back through MCU(flashed through JTAG) it is giving 16 E7 A4 E3 value.
If i write and read back the data through MCU the data is matching and if i signal tap the readdata signal on Avalon MM interface while reading, it is reading the exact original data but if we examine through JTAG the data in CFM1 location is different.
Shiva.
