Shiva
7 years agoMAX 10 FPGA Remote System Upgrade (RSU)
Hi, I am trying remote system upgrade for MAX10 FPGA device, Here i am able to write and read the rpd data of CFM1 but when i trigger the reconfiguration it is not getting reconfigured. I am doing t...
JohnT_Altera
7 years agoHi Shiva,
If you are not able to examine correctly then I do not think that the data is written correctly.
Could you try to write the flash using JTAG and read the CFM1 and CFM2 data out using MCU? I would like to see if you are able to see the similar content just by reading through MCU. This to confirm that your design is working as it is.
Shiva
7 years agoHi,
No if i flash the data though JTAG and read back by using MCU the data what it is reading is different compared to original data.
what do you suggest from this?
Shiva.
