MAX 10 FPGA Remote System Upgrade (RSU)
Could you provide me your stp file which have the data you tap? May I know if the data being written to the flash through micro controller is the same as what you Signal Tap?
What i am telling is not through signal tap 2 logic analyzer.
We have implemented a logic to send and receive the data from micro controller to FPGA to on-chip flash memory.
If i send and receive the data using Micro controller to the On-chip flash the whole data is matching exactly with respective its address locations. So, we are able to write and read the data correctly into On-chip flash memory.
But if i flash the code using JTAG and read the data using the Micro controller it is not matching with the POF file.
So, i feel like there is specific format to write the data to on-chip flash memory(like how the JTAG is writing the data to flash memory). We may be missing this format while sending data to On-chip flash memory which may leads it not getting reconfigured.
Can you help me to understand the exact format to be followed while writing the data to flash memory?
Shiva.
