Shiva
7 years agoMAX 10 FPGA Remote System Upgrade (RSU)
Hi, I am trying remote system upgrade for MAX10 FPGA device, Here i am able to write and read the rpd data of CFM1 but when i trigger the reconfiguration it is not getting reconfigured. I am doing t...
JohnT_Altera
7 years agoHi Shiva,
From the pof file read out, I observed that the content of CFM1 is incorrect when comparing to your generated RPD file. It is different from what you observed through STM32 microcontroller SPI interface.
May I know if you are able to check if what you send or received from SPI interface is correct to the Avalon-MM interface? May I know if you are using internal Oscillator or external clock for your On-Chip Flash IP? If you are using internal Oscillator then could you switch it to external clock?
Shiva
7 years agoHi,
Yeah, the data what we are sending and receiving from SPI interface is correct and the same data is going to the Avalon-MM interface.
We are using external 100MHz oscillator for clocking.
Shiva.
