MAX 10 FPGA Remote System Upgrade (RSU)
May I know how do you generate the rpd file? How do you compare the flash content to be correct? Are you able to share with me the rpd file and the read out file from the flash?
Could you also try to use Quartus Programmer to examine the flash content?
I am generating the rpd file by going through convert programming files -> internal configuration(mode) -> .pof(programming file type) -> file name -> selecting 1.create memory map file 2.create config data RPD -> Under input file to convert adding the sof file two times, and then selecting the Generate option.
After this the tool is generating the .map, .pof, .rpd(combined), cfm0_auto_rpd, cfm1_auto_rpd, ufm_auto_rpd files. From these files we are sending the cfm1_auto_rpd file to onchip flash memory.
After writing the rpd file data we are reading the data from onchip flash. This data is matching with the original rpd file data.
Please find the following attachment of rpd file and read_out_rpd file.
Shiva.
