Shiva
7 years agoMAX 10 FPGA Remote System Upgrade (RSU)
Hi, I am trying remote system upgrade for MAX10 FPGA device, Here i am able to write and read the rpd data of CFM1 but when i trigger the reconfiguration it is not getting reconfigured. I am doing t...
JohnT_Altera
7 years agoHi,
From your information provided, the step looks correct and I assume that the data is written correctly to CFM1 and CFM2. Could you read the msm_cs value of the dual boot IP?
Shiva
7 years agoHi,
I tried to read the msm_cs value from dual boot ip by giving the offset 4, the dualboot ip is giving all 1's from [16:0] and all 0's from [31:17](checked in the simulation). Which means the msm_cs value is 1111 (16:13). This indicates it is not matching with any msm_cs values.How can i get the correct msm_cs values.
while doing this remote system upgrade i never used the watch dog timer, if this is the problem can you provide the information regarding how to enable and use the watchdog for reconfiguration success.
Shiva.
