MAX 10 FPGA Remote System Upgrade (RSU)
Hi.
May I know how do you trigger the reconfiguration? Do you change the "config_sel_overwrite" bit and "config_sel" bit on Dual Configuration IP before triggering reconfiguration?
You may refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf table 34.
Hi John,
Thanks for the reply.
yeah i changed the "config_sel_overwrite" and "config_sel" bits to high and then triggered the reconfiguration but it is not getting reconfigured.
Here if i flash the .pof file which contains both factory image and application image it is reconfiguring but if the send the RPD data of CFM1 to on chip flash memory through avalon memmory mapped interface and if i trigger the reconfiguration it is still at CFM0(not reconfiguring). The .pof and .rpd files are generated by using the Quartus prime 16.0 lite edition. Does it makes any difference with .pof and .rpd files.
shiva
