MDISC
6 years agoMAX 10 FPGA JAM Staple error
Hi, I am trying to program a MAX10 FPGA device by embedded JAM Staple utility modified to run on microcontroller on my board. I am able to do this operation when the device is already programmed s...
YuanLi_S_Intel
6 years agoHi Marco,
Can you to program the JAM created with POF? Also, may i know what is the download cable used for this? Also can you check if the memory for the host processor is sufficient?
Thank You
