18 years agoLoading file from working folder
Hi guys, I am currently using the Altera UP2 Educational Kit to perform convolution on images. I was hoping to write a program which allow my board to load a binary file (.bin) from my current...
18 years agoHello,
I can give you an example:test2:
if test=2 generate
Process
file IN_DAT : text open read_mode is "Omnikey.txt";
variable LI: line;
variable MV: integer;
Begin
wait for 1 ns;
while not (endfile(IN_DAT)) loop
wait for 10.26 ns;
readline (IN_DAT, LI);
read (LI, MV);
adc <= std_logic_vector(conv_signed(MV,12)) XOR X"800";
end loop;
file_close(IN_DAT);
wait;
End Process;
end generate; The data file looks like this (more lines to follow): -25
1194
1681
1096
-293
-1439
-1755 adc is an input port for a 12 bit ad converter at the DUT. The 10.26 ns cycle isn't the adc sampling rate, but the corrected sampling rate of recorded test data, this way I present realtime test data with correct timing. I hope that helps, Frank
