14 years agoLaboratory Exercise 12
Hello, I need a help to solve the first part of exercise 12, Basic Digital Signal Processing. I'm using the libraries provided "lab12_design_files." Insert the following code in the correct ...
13 years agoHi, I haven't look at the schematic of the board neither functionnal chronogram nor truth table. So I may be wrong.
But it sounds quite trivial : read data from one component and write data to an other component. Even if we talk about one component : codec but it can be considered as 2 independant components : coder and decoder. In your code above, you wrote process(clock_50) but clock_50 is not used in the process. First draw a very simple schema with D flip flops and translate it to VHDL. VHDL is a hardware description language. You spent too much time by trying to make it work by "trial and error". I hope the board is functionnal ;-)
-- one clocked process to read data from codec
process(CloCK_50)
begin
if rising_edge(clock_50) then
if read_ready = '1' then
read_s <= '1';
end if;
end if;
end process;
-- one other process to write data to codec
process(CloCK_50)
begin
if write_ready = '1' then
writedata_left <= readdata_left;
writedata_right <= readdata_right;
write_s <= '1';
end if;
end if;
end process;
@sethjones : could you put the scheme
