14 years agoLaboratory Exercise 12
Hello, I need a help to solve the first part of exercise 12, Basic Digital Signal Processing. I'm using the libraries provided "lab12_design_files." Insert the following code in the correct ...
14 years agoFirst, make a schema with logics. (more complex schema needs good writing)
I guess you want to copy readdata_left to writedataleft and same thing for 'right' You might use a synchronous logic (recommended) by using process(clk) because of possible glitches. look for "process(clk)" or "synchronous process) even in quartus help Something like : process (clock_50)
begin
if rising_edge(clock_50) then
-- not verified at all --
if(write_ready='1' and write_s='0') then
write_s<='1';
writedata_left <= readdata_left;
writedata_right <= readdata_right;
end if;
end if;
end process;
