9 years ago
Lab 12 Part II Noise Filtering
Hi everyone!
I've been trying to make noise filter for input mic as requested in Lab 12 but I've been having some really strange issues.
Lab link ftp://ftp.altera.com/up/pub/altera_material/12.0/laboratory_exercises/digital_logic/de2-115/verilog/lab12_verilog.pdf
So what I do is whenever I got input signal I divide it by 8 and write it in FIFO. On the output I always keep sum of all FIFO registers.
The strange thing that happens is, that it is working perfectly fine when I am not dividing by anything (Just outputing the sum of all registers), and when I am dividing by 8 I only get noise as the output.
Does anybody have any idea what might cause this issue ?
Here is my code in case you couldn't understand what I've been saying :D
// synopsys translate_off
`timescale 1 ps / 1 ps
// synopsys translate_on
module noise_filter # (
    parameter DATA_WIDTH=24,
    parameter N = 4
    input write,
    input clock,
    input  data_in,
    output done,
    output  sum
    reg  summed;
    reg  counter;
    reg isDone;
    reg  fifo ;
    integer i;
    initial
    begin
        counter = 0;
        summed = 0;
        isDone = 0;
        for(i = 0; i < 2**N; i= i+1)
        begin
            fifo = 0;
        end
    end
    always @(posedge clock)
    begin
        if(isDone == 1)
        begin
            isDone <= 0;
        end
        else if(write == 1)
        begin
            counter <= counter + 1;
            fifo <= {{N{1'b0}}, data_in};
            summed <= summed - fifo + data_in ;
            isDone <= 1;
        end
    end
    assign sum = summed;
    assign done = isDone;
endmodule
So long story short, this outputs just random noise, and with this change
  fifo <= data_in;
  summed <= summed - fifo + data_in;
it works perfect.
Thanks everyone!
