15 years agoJTAG Bahvior is Different from EPCS4
Hi all, I have a DE1 board. I design a circuit, very simple circuit with one 8-bit counter. It has a PLL in it too. The PLL generates 50 MHz input clock and bring it down to 10 MHz. When I p...
15 years agoHi,
1) Do you have a explicit reset in your counter ? 2) Do you check you output configuration for epcs ? I mean there may be a problem with your epcs : program file or design. I suspect program file (.pof). 3) Else...
