9 years agoIs there a best practise to build a Clock Synchronizer for a Cyclone IV or V?
I'm teaching techniques to cross clock domains (CDC), and I need to develop some demonstrators. For some techniques, you would cascade D-Type FlipFlops without any combinational logic between t...
9 years ago --- Quote Start --- I'm teaching techniques to cross clock domains (CDC), and I need to develop some demonstrators. For some techniques, you would cascade D-Type FlipFlops without any combinational logic between them. These D-Types also need to be as close as possible, and have the fastest setup time possible of course. We are using a Cyclone IV on a DE0-Nano board, but I assume the issue is the same for the DE1 boards (which we will move to next year) It's straightforward to write VHDL to build a clock synchroniser. The issues I am uncertain about is how to constrain the synthesis to minimise mtbf. Maybe there is a standard component that allows me to build a clock synchroniser? (I could not find one). Many thanks in advance. --- Quote End --- I wire two registers directly...and leave it to tool. The ideal is balanced setup/hold rather than best setup. You may therefore add max/min delay on that path to target balanced timing but I never done that. you also need false path at cross over. dual clock fifos sdc may give better details.
