12 years agoIS it Possible to display bmp image read from SDRAM
Can any one tell us pls. I am using DE0 board. Reading bmp image from SDCARD display it on VGA instead of SRAM buffer i m using SDRAM. is it possible to display the bmp image.
12 years agoHi balakumar,
I'm doing the project containing display image stored in SD card, on VGA. Now, I write the module that read successfully data from SD card, but SD RAM and VGA are the tackles. Could you help me ? By the way, are you using Nios-II or STORM SoC for integrating all of those components ? Thanks,
