12 years agoIS it Possible to display bmp image read from SDRAM
Can any one tell us pls. I am using DE0 board. Reading bmp image from SDCARD display it on VGA instead of SRAM buffer i m using SDRAM. is it possible to display the bmp image.
12 years agofor(x=0;x<54;x++){
header=(unsigned char)(alt_up_sd_card_read(sd_fileh)); } this will read the header info of bitmap file..then read the bgr info of bitmap ... (RGB value is stored in reverse).. tats only i used for to read bgr.. the bitmap file is 24 bit format... i have used pixels value converted into 16 bit format... i have tried for 24 bit also but not getting the exact ouptut..while using 16bit means it shows the exact output on VGA...
