12 years agoIS it Possible to display bmp image read from SDRAM
Can any one tell us pls. I am using DE0 board. Reading bmp image from SDCARD display it on VGA instead of SRAM buffer i m using SDRAM. is it possible to display the bmp image.
12 years agoYes it's possible.. But you have to do the work to make it happen.
If you already have the BMP decoded in SRAM, you just need to send to to the VGA DAC's with the appropriate timing. for the resolution in question.. A place to start is: http://en.wikipedia.org/wiki/video_graphics_array This place has all the correct video timings for different display resolutions. http://tinyvga.com/vga-timing The OLD crt displays were much more forgiving than new LCD panels on display timing. If you aren't close, most likely they will just remain blank. Get the timing correct, you should start seeing an image. I would just try a constant color frame first, until you get the display up, then move forward with the bmp data. Pete
