12 years agoIP Core compatibility with High Capacity SD Card (SDHC)
Hi I'm using the university program IP core for SD Cards. I think it was designed to be used with standard capacity SD Cards (specifcation V1) (up to 2GB). I have performed tests with standar...
11 years agoI'm also having this problem. I've heard there are some compatibility issues with certain SD card brands, but haven't been able to find which specific ones work. Did you ever find a solution to your issue?
