14 years agoInterfacing DE2 board (TV video in) and 2.4GHz Wireless AV Camera Receiver
Hi, Anyone try to interface DE2 board (TV video in) with 2.4GHz Wireless AV Camera Receiver and output display to VGA? I had tried the code that I attached but seem like it does't work for the ...
14 years agoHello, I have to use the RGB signals for another purpose, so i divide the demonstrator in two blocks, one that generate the RGB signals and other that put it in the VGA output.
I didnt change the code, but some vertical lines are appearing over the video. is this your problem also? Anyone knows why? did you try putting the camera in NTFS? Eze
