Intel/Altera Monitor Program - freeze
- 3 years ago
According to this link here:https://fpgacademy.org/tools.html
The available versions for the monitor program are 18.1 and 21.1 only. Do take note, the Monitor Program version has to match your version of the Quartus Prime software meaning the .sof file produced has to be either 18.1 or 21.1 to use the monitor program.
I will check with the internal engineering to see if they have any future developments on this program and get back to you as soon as I have any news.
Thank you.
Kelly
Thank you.
Kelly
Thank you for your reply
Probably adopting 21.1 would bypass the problem, but since I've installed 22.1, I do not think to downgrade the version till the problem is limited to this nuisance, in the feature, if I'll decide to make this step I'll give you feedback.
