intel quartus license setup window is not working in ubuntu
- 5 years ago
Hi Qazi,
Still cant see the email. Can you check your private message?
Hi Qazi,
From your link given, I can see you are struggling with Quartus and device installation. Please make sure all the installation is good. By default there should not be a blank. Refer to the document below related to Intel® FPGA Software Installation and Licensing.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/quartus_install.pdf
- Qazi_Shahid5 years ago
I have uninstalled the software and installed the libraries suggested (Although I found that all those were already installed).
But even after that when I reinstalled the software the problem is still exist.
They software is still asking for licenses everytime I open it and then ask to installed any device. but during installing the cyclone V device it again gives that error that
"error reading INI file".
Also where is this INI file located. I didn't found in any location.
I had seen somewhere on web that it should be in .alter.quartus but this directory only contains quartus2.qreg file.
