Qazi_Shahid
5 years agointel quartus license setup window is not working in ubuntu
I have installed intel quartus prime standrad edition and running sudo ./quartus from directory home/intelFPGA/20.1/quartus/ the license setup window appears but it is blank, so I cannot add the lice...
- 5 years ago
Hi Qazi,
Still cant see the email. Can you check your private message?
SyafieqS
5 years agoHi Qazi,
Could you install following libraries?
Install libc6:i386, libncurses5:i386, libxtst6:i386, libxft2:i386, libstdc+
+6:i386, libc6-dev-i386, lib32z1, lib32ncurses5, lib32bz2-1.0, and libpng12
libraries.
Note: • For Ubuntu 18.04, additionally install libqt5xml5 and liblzma-dev libraries.
Once done, reinstall Quartus Prime. You may need to refer to document below related to
Intel® FPGA Software Installation and Licensing
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/quartus_install.pdf
Then make sure the device .qdz file is in same directory with Quartus installer. Install the device support.
