Qazi_Shahid
5 years agointel quartus license setup window is not working in ubuntu
I have installed intel quartus prime standrad edition and running sudo ./quartus from directory home/intelFPGA/20.1/quartus/ the license setup window appears but it is blank, so I cannot add the lice...
- 5 years ago
Hi Qazi,
Still cant see the email. Can you check your private message?
Qazi_Shahid
5 years agoIt ran successfully after deleting the sudo word in the terminal
command to run:
sudo ./quartus (didn't work)
./quartus (worked)
After that I gave the license file location.
But it is asking for a license file each time I restart the quartus software.
It also ran into some other error Which I mentioned here.
Kinldy look into it.
