Intel FPGA SDK for OpenCL: Issue while launching same opencl kernel multiple times
- 2 years ago
Hi @chandrasekhar92,
Noted that there seems to be a custom BSP involved. Is it correct to say there is no references design you are referring to and sample code are based on self written?
After going through the situation, using clWaitForEvents to synchronize kernels in separate queues are working from previous experiences. Would recommend to try clFinish() which has similar purposes to see if that works.
Also for the mention situation, it seem that the desire execution flow are out of order, hence below links would also explain that:
Note: link mention are for example with GPU as the hardware, however the execution concept are the same.
Best Wishes
BB
Great! Good to know that it is working now and thanks for sharing your steps here with others, with no further clarification on this thread, it will be transitioned to community support for further help on doubts in this thread. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
Thank you for the questions and as always pleasure having you here.
Best Wishes
BB
