MPfaf1
4 years agoIntel FPGA Monitor Program 21.1 with Quartus Prime Standard 21.1
just trying to upgrade from 18.1 to 21.1. Unfortunately the Intel FGPA Monitor Program 21.1 will not work with the current version of Quartus Prime Standard (also 21.1).
I am aware of the ...
EBERLAZARE_I_Intel
4 years agoHi,
Do you have update from your side?
- MPfaf13 years ago
just made a new attempt to make the intelFPGA Monitor Program run with a Quartus version 21.1 on a brand new computer running a fresh Windows 10.
WSL is installed on my computer. Still the Monitor Program does not work and shows all the symptoms already given above.
Please try that yourself. But not only up to the installation of the University Progam installer. Instead go ahead, and connect a board (I'm using the DE1-SoC) and try to go through the ARM A9 Tutorial (which you may find in the Help menu).
You will not even be able to download anything to the board.
Markus
