Intel FPGA Monitor Program 21.1 with Quartus Prime Standard 21.1
Is it for both NIOS II and ARM that your are not able to download anything?
For checking purposes, can you confirmed that your NIOS II command shell can be open for the 21.1?
- MPfaf14 years ago
currently I’m on vacation which slows things down a bit. But as far as I remember I needed to install WSL after installing Quartus 21.1 to make NIOS command shell run. Still not even the Download from FPGA Monitor program to the DE1-SoC board worked. But I’m sure, this is not new to your since you have of course tested this yourself minutely.
Since everything is working in Quartus 18.1 and the steps needed to make 21.1 working with the Monitor program need to much effort from our system administrators here at the university the best way seems to be to stay at this version for use of the Intel FPGA Monitor Program and to wait for a working version of Quartus.
Markus
