Intel FPGA Monitor Program 21.1 with Quartus Prime Standard 21.1
Yes from my understanding, you need to install WSL and the necessary steps when installing Nios II in Intel® Quartus® Prime Pro Edition version 19.2 and Intel® Quartus® Prime Standard Edition version 19.1
- MPfaf14 years ago
to clarify once again:
The problem this thread is about arises when you do the following things:
- Install Quartus Prime Std. Version 21.1
- Install Univerisity Program Installer 21.1 on top
- Error: Try to use the Intel FPGA Monitor Program which will not be able to download anything to the FPGA board (DE1-SoC).
This thread does not deal with NIOS II, or version 19.1. of Quartus in any other way than that the problem already existed there (though there is no such thing like university program installer for 19.1)
Result:
You confirm that the problem first existed in 19.1 still exists in Quartus Prime Std Edition 21.1. Is that correct?
In this case I'd propose to give users a warning on this fact when they download the university program installer for version 21.1.
Will there be a Quartus Prime Std version in the future that does no longer have this problem?
Markus
