MPfaf1
4 years agoIntel FPGA Monitor Program 21.1 with Quartus Prime Standard 21.1
just trying to upgrade from 18.1 to 21.1. Unfortunately the Intel FGPA Monitor Program 21.1 will not work with the current version of Quartus Prime Standard (also 21.1).
I am aware of the ...
EBERLAZARE_I_Intel
4 years agoHi,
Could you shared your 18.1 design here?
- MPfaf14 years ago
there is no such "18.1" design from my side. All designs come directly from Intel/Altera
The problem is already there if you just do the ARM Tutorial:
- Simply do a fresh install of Quartus Prime Standard 21.1
- Install the university program installer 21.1 in addition.
- Then try to do the ARM tutorial you will find in the Help menu of the Intel FPGA Monitor Program
Result: See picture attached to my inital post.
Problems are known since the 19.1 version of Quartus Prime Standard:
Be aware that the Standard version is the one I'm talking about here (not the Pro).
