Hi!
I am a DE1_SoC user. I am using Quartus prime lite 16.1, and I am working on an Intel FPGA monitor program tutorial. In the project creation stage, an error message appears stating that the cab...
You shouldn't have to manually specify javaw.exe every time. I assume that you are using Windows. Are you running the monitor program from the Windows shortcut that was created by the installer. If yes, what is the "Target" of that shortcut (ie. what is the shortcut trying to run). It should be something like: 'C:\intelFPGA\16.1\quartus\bin64\jre64\bin\javaw.exe -Dsun.java2d.noddraw=true -jar C:\intelFPGA\16.1\University_Program\Monitor_Program\bin\Altera_Monitor_Program.jar'
Quartus was 16.1 and only one was installed. The monitor program was originally installed to 16.1, but due to the same problem, I upgraded to 18.1. When installing the monitor program, it was installed as it was because the program automatically set it to "c:\altera" in the item asking for the installation path. Today, while installing 16.1 again, I changed it to "C:\intelFPGA_lite" and installed it, but the phenomenon is the same. How do I change the QUARTUS_ROOTDIR setting? Please gave me the detail guide.
However, running Quartus should update the environment variable automatically. You can use the steps in the link above to view your environment varaibles to make sure that it is set properly.
Thanks to your great support, I could go further more. But Unfortunately, I have another issue to download the code into device. I leave the process message as below.
I can't understand this error message "Could not query JTAG Instance IDs. Please ensure the FPGA has been configured using the correct .sof file."
