17 years agoImplementation of Digital PID controller in FPGA
I'm trying to implement a PI controller in FPGA using schematic entry method in altera quartus II . I'm using the following equivalent PI controller equation, c(n) = c(n-1)+kp*(e(n)-e(n-1))+Ki...
14 years ago --- Quote Start --- The board link is the website link, sorry for confusing you :) --- Quote End --- Ah, I see. The DE2-70 has plenty of logic for a PID controller. The lower-cost DE0-nano, BeMicro, and BeMicro-SDK boards would also have enough logic. What is just as important, is what are your I/O requirements? Does your PID controller need an ADC or a DAC? How are you going to interface to the real-world? You need to look at both the FPGA board and the interface boards, and make sure you can connect them together without too much work. The DE2-70 and DE0-nano interface to boards via their GPIO headers. Terasic have some ADC/DAC boards. The BeMicro and BeMicro-SDK boards have an 80-pin edge connector. You can connect a PROTO board to that header for interfacing to custom logic. Cheers, Dave
