17 years agoImplementation of Digital PID controller in FPGA
I'm trying to implement a PI controller in FPGA using schematic entry method in altera quartus II . I'm using the following equivalent PI controller equation, c(n) = c(n-1)+kp*(e(n)-e(n-1))+Ki...
14 years ago --- Quote Start --- You'll need to clarify what you mean by "board link". The board has an Embedded USB-Blaster circuit on one of the USB connectors (it should be written on the PCB silkscreen next to the connector). I think its the outer-most connector (nearest the edge of the board). The other two USB connectors are connected to a USB PHY for custom applications. Cheers, Dave --- Quote End --- The board link is the website link, sorry for confusing you :) "To be able to post links or images your post count must be 4 or greater. You currently have 3 posts. Please remove links from your message, then you will be able to submit your post."
