17 years agoImplementation of Digital PID controller in FPGA
I'm trying to implement a PI controller in FPGA using schematic entry method in altera quartus II . I'm using the following equivalent PI controller equation, c(n) = c(n-1)+kp*(e(n)-e(n-1))+Ki...
17 years agoWarning (14130): Reduced register "lpm_dff0:inst9|lpm_ff:lpm_ff_component|dffs[0]" with stuck data_in port to stuck value GND
Warning: Output pins are stuck at VCC or GND Warning (13410): Pin "output[0]" is stuck at GND These warnings make sense after looking at the schematic. The two multipliers before the add are doing a multiply by 2 so the result will always be even, thus bit 0 will always be 0. Also noticed that The two dff on the top left(inst1 and inst2) are 16 bit but should be 8bit. When I double click them, the megawizard shows them as 16 bit. Not sure if this is a problem. I fixed that issue and ran a modelsim simulation and the simulation shows data coming out of the dff of inst9. synthesized_wire_11 is the output of dff(inst9)
