17 years agoImplementation of Digital PID controller in FPGA
I'm trying to implement a PI controller in FPGA using schematic entry method in altera quartus II . I'm using the following equivalent PI controller equation, c(n) = c(n-1)+kp*(e(n)-e(n-1))+Ki...
17 years agogmpstr,
Thanks a lot for response. I used D type flip flop and I sucessfully implemented kp*(e(n)-e(n-1))+Ki*T*e(n-1) but once I took the c(n) and pass it through D type flip flop to get c(n-1) and add to above, my problem started. The value of c(n-1) is always zero though it acutally is not and the result is just always equal to kp*(e(n)-e(n-1))+Ki*T*e(n-1). During synthesis, I got the following warning, Warning (14130): Reduced register "lpm_dff0:inst9|lpm_ff:lpm_ff_component|dffs[0]" with stuck data_in port to stuck value GND Warning: Output pins are stuck at VCC or GND Warning (13410): Pin "output[0]" is stuck at GND Maybe this will help you understand my problem. I hope to get feedback from you in this matter.
