14 years agoIDE newbie question
Hey yall. Im using NIOS II IDE ,ad I want to use some Altera university IP cores, I follow the PDF that comes with my version of the suite. BUt I get a really weid error. When I tell it to comp...
14 years agoYes That is exactly what I have tried to do. I have dumped the contents of the university program in there but still I get problems.
I haven't however found the exact instruction of how to properlly tell the compiler to took in those folder... but as you see on the picture, the files are in the IDE under the Altera.Components tree inside of Eclipse. Still today no luck. I'm on version 9.2 Can if you would kindly explain to me how to add the compiler to search inside of those folders for those .h and .C files. Thanks Gabriel
