HBin0
6 years agoI use DSP Builder in Quartus Prime Pro 19.4, When I setup generate hardware option in CONTROL BLOCK, run simulink simulation , failure is reported
Error reported by S-function 'mip_control' in 'lms/Control': Failure to redistribute delay in [lms_Subsystem] - negative cycle (0) Sub | lms_Subsystem | { } (0) Add_PostCast_primWireOut_sel_x | l...
HBin0
6 years agoWhen I don't select generate hdl hardare option, run Simulink simulation , the result is correct。so, you should let Factory help me to find issue.
