RThie6's avatar
RThie6
7 years ago
I recently installed altera univerity program. Some Ip cores are visible but not all.
I only get to see SRAM controller and SSRAM controller.
They are located in the 18.1/ip/altera/university_program/Memory.
I also want to test altera_up_sd_card_avalon_interface. How can I change this. Tried to add the directory to the search directory, but this doesn't help.
  • JohnT_Altera's avatar
    JohnT_Altera
    The Altera University Program IP can only be instantiated through Platform Designer or Qsys.
  • RThie6's avatar
    RThie6
    Hi Johh,
    You are right and that is also the place where I was looking.
    I know all the files alre in teh right directory, but Platform Designer nor Qsys don't show the SD card ip.
    JohnT_Altera
    May I know if you observed "University Program" inside the IP Catalog? Could you provide the screenshot of the Platform Designer or Qsys? May I know which Quartus version are you using?
  • RThie6's avatar
    RThie6
    I am using Quartus 18.1.
    ScreenshotPlatform designer attached. SD_card Ip is not visible although it is located in the 18.1/ip/altera/university_program/Memory. directory.
    JohnT_Altera
    Please use Quartus 17.1 to instantiate it as it has been removed from latest Quartus.
