BlackByte10xy
5 years agoI have a question about verilog!
I have a compile error in quartus II when I try to do a counter with asynchronous reset. The error comes from the sensitivity list of the always process. The part of the code is as follows: ...
RichardT_altera
5 years agoYou may checkout the webpage below to help you on the Verilog design.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/design-examples/desig...
Other than that, our Quartus tool has a variety of Verilog design template in which you can just pop it into your project and use it right away.
Example:
In the new created Verilog .v file, right-click on the black space to opens the context menu, scroll to Insert Template, a window Insert Template will pop up, choose Verilog HDL > Full Designs > Counters > Binary Counter.
