16 years agoI dont wont to save the "space" in SRAM, Help me ?
Hi every body ...
i wrote a code that receive data RS232 and save it on the SRAM ... and its work http://www.edaboard.com/images/smiles/icon_smile.gif But i have problem... i don't wont to save a " space " ,which equal 20 in hex, with the data ...i tried to modify my code but i failed i dont know what is wrong with my code ?? :/ when i send the data like ( for example) >>>1 then 2 then "space" then 3 then 4 the data saved like this in SRAM >>>> 1 then 2 then "space" then 4 i dont know why it save the "space" and skip 3 >>???? this is my whole project : # ########################################## module serialfun(clk, RxD, RxD_data, nWR,nCE, nRD,Address, Data_Bus,LED,Data_In,nUB,nLB,RxD_endofpacket,RxD_data_ready,RxD_idle,WE); input clk; input RxD; output RxD_idle; output RxD_endofpacket; output RxD_data_ready; output nRD; output nWR, nCE; output reg WE; output [17:0] Address; inout [7:0] Data_Bus; output [17:0] LED; output nUB,nLB; /////////////////////////////////////////////////// //wire RxD_data_ready; output [7:0] RxD_data; async_receiver deserializer(.clk(clk), .RxD(RxD), .RxD_data(RxD_data), .RxD_endofpacket(RxD_endofpacket),.RxD_idle(RxD_idle),.RxD_data_ready(RxD_data_ready) ); /////////////////////////////////////////////////// always @(posedge RxD_endofpacket) if(RxD_endofpacket==1) begin if ( RxD_data == 8'b00100000) WE=1'b0; else WE=1'b1; end /////////////////////////////////////////////////////////// //assign Data_Bus = WE? RxD_data : 8'hzz; input [7:0] Data_In; reg [17:0] Address_In ; /////////////////////////////////////////////////////////// MEM_SRAM u0(.Data_Bus(Data_Bus), .Address(Address), .nRD(nRD), .nUB(nUB), .nLB(nLB), .nWR(nWR), .nCE(nCE), .Address_In(Address_In), .Data_In(RxD_data),.LEDR(LED),.RxD_endofpacket(RxD_endofpacket),.WE(WE)); endmodule # ############################################# module MEM_SRAM ( Data_Bus, // Data Bus Address, // RAM Address nRD, // RAM Read Enable nWR, // RAM Write Enable nCE, // RAM Chip Enable nUB, // RAM Upper Byte nLB, // RAM Lower Byte Data_In, Address_In, RxD_endofpacket, LEDR, WE, clk); // Write Enable output reg [17:0] Address; // RAM Signals // include inout [7:0] Data_Bus; output nRD, nWR; output nUB, nLB; output nCE; input WE; // Write Enable input [17:0] Address_In ; input [7:0] Data_In; input RxD_endofpacket; output [17:0] LEDR; // include reg input clk; assign nUB = 1'b1; // Disable Upper Byte assign nLB = 1'b0; // Enable Lower Byte assign nCE = 1'b0; // Enable Chip assign nRD = 1'b0; // Read Enable assign nWR = !WE; // Write Enable assign Data_Bus = WE? Data_In : 8'hzz; always @(posedge RxD_endofpacket) if(RxD_endofpacket==1) begin if(WE==1) Address <= Address + 1; //else //Address <= Address + 0; end assign LEDR = Address; endmodule PLZ... help me http://www.edaboard.com/images/smiles/icon_sad.gifNo RepliesBe the first to reply
