16 years agohow to use getch in niosII
hi i want to ask what is the header file to add for using getch in niosII. I had try to add conio.h but it say that No such file or directory. thx for helping:)
16 years agoYes, now i trying to use getchar() but there still some problem with it because i using "string" to do it but when i change to "int" or "char" it can be done. The problem is when i using string the password that i type out is correct (i already prove by typing: printf (%s, &password) ) but it still cant be match with the password that i had set. I making a program that need to type password to log in, when typing password those character will become ***, by the way i still dun know the programming change to *** is correct or not. Thx for helping
my coding show as below:# include <stdio.h># include <stdlib.h># include <unistd.h># include <string.h> void one(); void two(); int login ; int user ; char password[10]; int i = 0; char c; int main () { while(1){ printf ("---------------------------\n"); printf (" Main Menu\n"); printf ("----------------------------\n"); printf (" 1.Admin login\n 2.User login\n"); scanf("%i", &login); if (login == 1) two(); if (login == 2) printf ("Display\n"); } return(0); } void one() { menu: printf ("---------------------------\n"); printf (" User Menu\n"); printf ("----------------------------\n"); printf (" 1.Check User\n 2.Delete User\n 0.Main Menu\n"); scanf("%i", &user); if (user == 1) printf ("CHECK\n"); else if (user == 2) { printf ("DELETE\n"); } else if (user == 0) main (); else if (user != 1,2,0) { printf ("Wrong key please retry\n"); goto menu; } else NULL; } void two() { printf ("Please enter password: "); enter: scanf("%s", &password); { while(i<5){ c = getchar(); password = c;printf("*");
i++;
getchar();
i=0;
while (i<5)
printf("%c",pass); i++; } getchar(); } if (password == 'obc') { one(); } else if (password != 'obc') { printf ("Wrong password, please retype "); goto enter; } else NULL; } ps: previously those getchar i use getch for it
