how to unlock the board after secure JTAG enable??
I am using the file from AN 556 provided from FAE.
and followed it to issue NPULSE_CONFIG JTAG intruction .
But my board is locked up after reboot!! I can't erase, load or do anything . How do I unlock my board to erase or program different
image? Please help
[nyup@labOptiPlex2 test_unlock]$ quartus_jli -c 2 unlock_208.jam -a unlock
Info: *******************************************************************
Info: Running Quartus Prime Jam Tools
Info: Version 18.0.0 Build 614 04/24/2018 SJ Standard Edition
Info: Copyright (C) 2018 Intel Corporation. All rights reserved.
Info: Your use of Intel Corporation's design tools, logic functions
Info: and other software and tools, and its AMPP partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Intel Program License
Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
Info: the Intel FPGA IP License Agreement, or other applicable license
Info: agreement, including, without limitation, that your use is for
Info: the sole purpose of programming logic devices manufactured by
Info: Intel and sold by Intel or its authorized distributors. Please
Info: refer to the applicable agreement for further details.
Info: Processing started: Fri Sep 20 14:33:36 2019
Info: Command: quartus_jli -c 2 unlock_208.jam -a unlock
Info: Using INI file /opt/intelFPGA/18.0/quartus/linux64/quartus.ini
Exit code = 0... Success
Info: Quartus Prime Jam Tools was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 194 megabytes
Info: Processing ended: Fri Sep 20 14:33:39 2019
Info: Elapsed time: 00:00:03
Info: Total CPU time (on all processors): 00:00:00
'Altera 2016
'Purpose: To unlock
ACTION unlock = DO_UNLOCK;
PROCEDURE DO_UNLOCK;
DRSTOP IDLE;
IRSTOP IDLE;
STATE IDLE;
IRSCAN 10, $208;
WAIT 100 USEC;
EXIT 0;
ENDPROC;
'Altera 2016
'Purpose: To unlock
DRSTOP IDLE;
IRSTOP IDLE;
STATE IDLE;
IRSCAN 10, $041;
WAIT 100 USEC;
EXIT 0;
ENDPROC;
1 Reply
- YuanLi_S_Intel
Hi Nhu,
I believe this is the duplicated case of 04355416. I will continue to support your request in this case 04355416.
Thank You.
