mitsvoid
2 years agoHow to test the FIR II filter
Dear All, I hope this message finds you well. I am currently working on a project involving an Altera DE2-115 board, where I aim to pass stored 32-bit ADC data through a FIR filter. Specifically,...
- 2 years ago
You can use the NCO IP core to generate a signal and to pass through the FIR filter in order to observe it with simulation or on Signal Tap.
Thank you,
Kshitij Goel
FvM
2 years agoHi,
you don't need NCO to test filter in simulation, just use sin() function in your testbench.
Another point, voice spectrum is about 300 Hz - to 3.4 kHz, applying a 300 Hz low pass leaves about nothing of speech signal. Do you mean high pass?
