15 years agoHow to supress hierarchy optimizer for logic cells?
Hi all! :) I'm a newbie here and in FPGA trips...:rolleyes: I'm trying to make a signal delay using AND ports and I'm having some difficult... At start, I need to delay a signal ~10ns...
15 years ago --- Quote Start --- Is the 4.25ns delay stable over the whole temperature range? Is it an average/min/max value? I'm not so sure you'll get an accurate delay with this method. --- Quote End --- I had no time to make all tests, but at ~18ºC of room temperature I used a spot light to increase board temperature and see no variation. Do you know a better method? I think I don't refer yet , but its for asynchronous delay.. I can´t use clock or pll signals to make it due to accuracy needed. # #edit## I'm performing a several tests and optimization and i'll put here some results :)
