RMart56
6 years agoHow to setup DE10 Lite for ADC with Potentiometer?
I recently purchased a DE10 Lite board and currently trying to set it up to read voltage from a potentiometer. I am not sure if I need to do anything special to accomplish this. However, I saw some d...
RMart56
6 years agoFirst of all, do I need to do any special configuration with the De10 Lite FPGA in order to read the analog voltage from a 10k ohm potentiometer voltage divider setup. If the answer is yes, then can you provide me with specific detailed instructions on how to proceed? If the answer is no, then can you point me to the document that can help me with the setup.
RMart56
6 years agoThe document is the platform designer.
