ZGhaz
7 years agoHow to re-activate failed fixed license in Quartus properly?
I recently bought Arria 10 SoC dev Kit. And I generated the fixed license come with it. but when I use it in Quartus Prime pro and try to compile any design, the following error comes up:
"Current license file does not support 10AS066N3F40E2SG device."
I generated the license many times using Self Service Licensing Center dashboard. but unfortunately no results.
Kindly, give us any work-around or ideas to fix this.
Thank you in advance.
Kind regards,
- ZGhaz
note:
last year, i installed a fixed license that came with another Arria 10 Soc dev Kit in using same PC and everything was fine.
- KhaiChein_Y_Intel
Can you provide the license.dat file for investigation ?
May I know which version of the software you are using?
