17 years agoHow to create echo delay in audio
Hello, im working on a project that needs to reproduce an audio signal using the the DE2 board. I need to create several effect for the final output, and one of them is the delay of the input signal ...
17 years agoAs a first remark, without signal and type definition, your code isn't understandable. I'm not motivated to guess about possible data definitions. Also the ADC and DAC data processing isn't clear, but it's not directly related to your question. I simply assume, that you are able to interface the audio codec correctly.
Echo usually implies a delay above 100 ms, respectively a few thousand samples, but may range up to many seconds. This can be done with RAM ring buffer, addressed by write and read pointers. The read pointer offset defines the delay. However, FPGA internal RAM is only sufficient for very small delays, external RAM would be better suited.
