How to convert an Analog voltage to Digital and display it to 10 LED using DE10-lite
I need help on how to convert an analog output voltage of a potentiometer to digital then display the digital value, per bit, to LED red (LEDR = DigitalVal[11:2]). I know how to code and how to display to LEDR but what I want to know is how to convert the Analog to Digital. I need the digital value. Could you please guide me on how to setup?
There is already a question on how to setup the DE10-lite for ADC but it didn't help.
- YuanLi_S_Intel
Hi Francis,
You will need an IP which converts analog input to digital for internal logic usage.
FOr MAX 10, i would suggest you to use MAX 10 ANalog to digital converter.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_adc.pdf
Please refer the user guide above for the usage of this IP.
Thank You.
- fmala
Hi SooY_Intel,
Thank you for the reply. To be honest, I have difficulty understanding all the information on your provided link. Is there any sample tutorial that shows a step-by-step procedure on how to setup/program the FPGA DE10-lite for ADC application like rotating a potentiometer and outputs its equivalent voltage on 7-segment? Can't find any. Just wanted to used it to my class, but it lacks resources.
Thank you.
- YuanLi_S_Intel
Hi Francis,
We do have sample design in our design store. Perhaps you can take a look. It might help you.
https://fpgacloud.intel.com/devstore/platform/15.1.0/Standard/gpio-qspi-flash-uart-adc-leds-switches-design-example/
Design Store example with ADC:
https://fpgacloud.intel.com/devstore/?page=2&search=adc
Thank You
